Yonghe OEM Parts
There has been much discussion regarding the obsolescence of so many ATV manufacturers. Most of these ATV's were produced with a cookie cutter design and the major differences are in appearance only.
New or Used Yonghe Parts
Search for new and used parts for all Yonghe ATV models. This may be the best option to track down rare, used items or obsolete ATV parts.
It's the place to browse if you're looking for a specific part for your Yonghe or you need to find a universal part to redesign or modify an older ATV. From a collectibility standpoint, sometimes you can stumble on an old magazine, a Yonghe brochure, or a Yonghe service manual as well.
High Demand Yonghe Queries
The following is a listing of high demand Yonghe queries for replacement parts and performance products.
- Tires
- Brake Pads
- Brake Rotor
- Battery
- Drive Belt
- Chain Sprocket Kit
- CV Joint
- CV Boot
- Axle
- Wheel Bearing
- Tie Rod End
- Body Panel
- Plastics
- Fender
- Carb
- Carrier
- Clutch
- Gearshifter
- Gasket
- Recoil
- Master Cylinder
- Pull Rope
- Starter
- Brake Drum
- Arm
- Seat Cover
- Cover
- Steering Shaft
- Knuckle
- Oil Pump
- Harness
- Connector
- Fuel Line
- Pedal
- Gear
- Cable
- Piston Ring Kit
- Motor
- Muffler
- Silencer
- Frame
- Bracket
- Alternator
- Rubber
- Plastic
- Ignition Coil
- Relay
- CDI
- Regulator
- Switch
- Button
- Cap
- Fuel Filter
- Petcock
- Capacitor
- Stator
- Winding
- Coverplate
- Gauge
- Handlebar
- Throttle
- Cable
- Spindle
- Castle Nut
- Rim
- Lever
- Bumper
- Oil Plug
- Head Gasket
- Hub
- Rubber Boot
- Pin
- Brake Assy
- Tensioner
- Adjuster
- Footrest
Yonghe Uploads
Please contribute to the Yonghe community. APL is looking for Yonghe wiring diagrams, photos of your personal Yonghe quad, and scans of service manuals. Any images that may benefit fellow ATV enthusiasts are welcome.
We are currently using a simple upload form for scans and images and accept some of the most popular file formats: .doc .pdf .jpg .png The upload form is simple and only takes a minute...
About Yonghe ATV's
Welcome to APL, a community-based site with information about Yonghe ATV's specifically sized for youth and beginner riders. APL features off-brand ATV Info, parts, and a troubleshooting forum.
Some brands of Chinese ATV's, in particular, have come and gone almost overnight. Use the community resources to troubleshoot and find parts and repair info for the Yonghe ATV and many others.
Yonghe is one of those companies who entered into the picture briefly. They were manufactured in China and mainly geared toward younger riders.
- Country of Origin: China
- Website: NA
- Available Sizes: 50, 90
- Models: Coming Soon
